Removing rear axle on 01 Recon
Old Dec 28, 2007 | 07:13 PM
Larryboy's Avatar
Default Removing rear axle on 01 Recon
I am trying to replace a rear outer wheel bearing on my 01 Recon. I have removed the 2 large nuts on right hand side on axle and I have tried to drive the axle out with no luck.
Have I missed taking something else loose? I was told that all I had to do was remove the 2 nuts and drive it out. Well it is not driving.
Before I get rough with it and break something thought I would ask.
thanks,
Old Dec 28, 2007 | 07:58 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
You don't have a service manual?
Old Dec 29, 2007 | 07:20 PM
Larryboy's Avatar
No, I do not have a manual. Honda mechanic told me today that I was doing it correctly but I have beat on it enough to start mushrooming the end of the axle. He told me they are very hard to remove and there was no certain tool for it other than protecting the axle end, So now I am still stuck.
I am thinking about drilling a hole in top of the tube and filing it with penetrating oil and let soak a day or two. I can weld hole (or put in a small bolt) and change rear end grease to get any that gets past seal when I get finished. Thoughts??
Old Dec 29, 2007 | 10:40 PM
Gimpster's Avatar
You have to remove the hubs, right brake panel (brake cover) and drive the axle out of the right side from the left side.
Which side, axle bearing are you replacing ?
----- Gimpster -----
Old Dec 30, 2007 | 02:26 PM
Larryboy's Avatar
Left side outer, had a squeaking sound and when I touched the axle by the housing looking for the source it was very hot. I had made a short round around neighborhood getting ready for a ride the next day. Good thing I did, I would have been a long way in woods when it burned up the next day. I have a problem now but that would have been worst. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 30, 2007 | 06:01 PM
Gimpster's Avatar
Fun... You may end up removing the seal and retainer ring, heating the bearing and working the axle both ways to get it to break loose
Old Dec 30, 2007 | 08:53 PM
Larryboy's Avatar
Got it out today, thanks for yall's advice. Bearing race was rusted to axle shaft, used a Dremel tool to cut it into and chiseled it out. It was quite a job. I will clean it up and put back together tomorrow.
thanks,
Old Dec 30, 2007 | 11:23 PM
Gimpster's Avatar
Good job man...
Sounds like it was a tough one. Especially when you say dremmel along with remove... hehehe
Sandman2.0
Jul 21, 2015 09:03 AM
tporath
Jul 11, 2015 12:31 PM
rcappie4
Jul 10, 2015 04:54 PM
MNatv89
Jul 7, 2015 11:36 AM
Rider252
Jul 6, 2015 03:37 PM
