etc adjustment help
Old Jan 14, 2008 | 09:06 PM
tanda's Avatar
Default etc adjustment help
i have a 2007 sportsman 500 EFI HO. i need the adjusting procedure for the etc.
bike will not start unless i apply a light throttle application. will not keep running if i let off the throttle completly. any help would be appriciated. newbe to the efi on quads.
thanks
tanda
Old Jan 14, 2008 | 10:23 PM
sheepdogMSP8117's Avatar
The ETC is preset (to the best of my knowledge) to detect when there is a failure with the cable/carb/throttle body which might cause the engine to keep running as if the throttle is still being applied. The ETC will cut the ignition under a situation where you release the throttle lever and the throttle cable sticks. Problem is, the ETC doesn't know the difference between a cable that is stuck open and one that just has too much slack in it. Both situations result in ETC shutting down the ignition.
So, if you take the excess slack out of the throttle cable, ETC won't shut it down anymore (if thats what the problem is). If you start where the throttle cable goes into the handlebar switch housing and work toward the headlight pod, you'll come upon a cover/sleeve that you can slide out of the way and it will expose the cable adjuster. Turn the adjuster one way or the other (one way will take up freeplay and the other way will add play) until you have I believe its 1/8" freeplay.
Also, you can search the POLARIS forum for "ETC" and you'll find lots of threads on this.
Let us know if it works for you.
<u>ADDED:</u>
Click HERE for recent info on this.
Old Jan 15, 2008 | 09:20 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if its too tight it will do the same thing as too loose as well.
Old Jan 15, 2008 | 06:18 PM
tanda's Avatar
Thanks much i wish everything was that asy to repair on this thing. i went out and in less than 30 seconds the bike was starting and idling like it was new again.
Thanks again! Tanda
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
wrencher82
Sep 30, 2015 04:27 AM
r1pilot83
Sep 27, 2015 07:38 PM
