hawkey problems
Old Jan 14, 2008 | 10:31 PM
jcop's Avatar
Default hawkey problems
dose any one have a Idea what could be wrong, we bought a hawkeye in august and it has a loud banging noise coming out of the clutch area the dealer took it apart and could find nothing, it is still making the noise, now it has 15 hours on it, I pulled off the air cleaner to check it and there is about a inch of oil and gas in it, then I checked the oil and it is full but smells like gas, it is still under warranty, dose anyone have any similar problems or ideas. Thanks
Old Jan 15, 2008 | 09:26 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
dont screw around w/ it wheres its under warranty take it back. show them the air box and the oil will need to be changed by the sounds. make sure they either hear that noise or at least document it so it it blows apart you have proof it was doing it when it was under warranty. imo
Old Jan 15, 2008 | 09:51 AM
GunnSmoke's Avatar
i had a problem with my first hawkeye... it was running like dog poop, blowing alot of smoke, filling the airbox with oil-gas and the oil level was super high (full of fuel).. i took it back to the dealer where it sat in the shop for 2 weeks... i told my dealer i wasnt a happy camper... good thing for me he replaced the machine with a new one.. they couldent figure out what was wrong with it.... they thought it was a carb problem and they said they re-built it (didnt help)... i wish i could help more.. if its under warranty make sure the dealer takes care of the problem...
Old Jan 15, 2008 | 12:12 PM
Rickeyparker's Avatar
Does it sound like a hammer noise that echos , or is it a thumping noise either way its under warranty, could be that the Carb is dumping fuel into the crankcase from a float thats stuck , if that be the case then it would smoke, is it smoking ?
Old Jan 15, 2008 | 01:21 PM
TennesseeTider's Avatar
Sounds like a bad bearing in the clutch cover.
Old Jan 15, 2008 | 07:30 PM
jcop's Avatar
its not smoking, it sounds like a hammer hitting metal and the noise is not always there, but it is there alot,mainly at low speeds or in reverse, I am going to change the oil and filter and the air filter because it is full of oil, if it persist I will take it in, the dealer looked at the noise one time but could not figure it out, I had another dealer tell me this is a common noise in the Hawkey.
Old Jan 15, 2008 | 08:41 PM
Rowe's Avatar
I bought a hawkeye in March of 07 it was @ the dealer 4x until I traded it in on my 500. If I were you I'd get it back to the dealer ASAP. Why spend more money on something that wasn't built right you just spent close to 5k, let them fix it.
Old Jan 17, 2008 | 02:15 AM
clutch bearing on the cover is more than likely the problem.
Old Jan 17, 2008 | 07:52 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i woulnt pay to change the oil or filters as it woulb under warranty most likey and you could ask them that before they do any work on it.
Old Jan 28, 2008 | 03:22 PM
drake2's Avatar
relax just clean up the oil(was probably overfilled and backed out when you were on a steep incline) and adjust your idle and throttle cable to fix the clutch from making that racket.you will have to play around with how the idle screw and throttle cable effect the machine.make sure that you can get the bike in gear.you will also find with a small engine like this that you might want to check those adjustments before you ride,especially if the temperature your elevation that your riding in is different than your last ride.hawkeyes a good bike just with the small engine /carb combination it can be very sensitive.
my experience
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
