LT80 help
Old Jan 20, 2008 | 05:07 PM
Dtrap's Avatar
Default LT80 help
Hey guys, I have a 98 suzuki LT80 that I can not keep running. It will start and run fine for about 5 minutes and then floods out. I then have to let it sit for hours to dry out before it will start agian. I have cleaned the carb well and this didnt help any. It floods to where gas drips out of the back of the motor where the exhaust bolts on. I think it needs a new needle and needle seat but can not figure out how to get the needle seat out of the carb. Any help or advice would be greatly appreciated.
Thank You
Dustin
Old Jan 20, 2008 | 05:25 PM
onebigzj's Avatar
Default LT80 help
try tapping on the carb while running. sounds like the needle is sticking open.
Old Jan 21, 2008 | 12:00 AM
LT80's Avatar
LT80 Expert
Default LT80 help
You remove the lil screw that holds down on the needle seat retainer.
Old Jan 21, 2008 | 12:36 AM
Dtrap's Avatar
Default LT80 help
Where is this little screw located at? I am not quite sure what you are talking about. In the expanded picture I have it looks like it comes out with the main jet. Do I need to remove the idler jet also? When I take out the main jet there is a small ruber gasket and it seems that the seat should come out after that. I have never removed one before though so I dont know.
Thanks for the help so far
Dustin
Old Jan 21, 2008 | 12:42 AM
onebigzj's Avatar
Default LT80 help
there is a (c) shaped piece of metal with a very little screw in itholding down the seat. you really cant miss it. when you take out the needle and float you will see it.
Old Jan 21, 2008 | 01:20 AM
Dtrap's Avatar
Default LT80 help
Ok I'm with you now. Thanks for the help.
Thanks
Dustin
Bob E.
Oct 1, 2019 09:08 AM
QuadRiders
Oct 22, 2015 04:13 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
Bergmann
Aug 13, 2015 03:51 PM
