Montana Jacks
Old Jan 28, 2008 | 12:37 AM
TheHun's Avatar
Default Montana Jacks
I've been lookig at bolt on storage devices and ran across Montana Jacks receiver hitch systems. Just wondering if any one has ran or is running any of their stuff?
[img]i/expressions/beer.gif[/img]
Old Jan 28, 2008 | 06:59 PM
pagerboy's Avatar
I have the receiver hitch system and it works good, I have the gas pack which I had to modify to take the bigger gas can.
Also have the winch rotator for plowing and it takes stress off the wire rope.
Old Feb 4, 2008 | 03:35 PM
pat89's Avatar
My receiver mount is due to arrive tomorrow. I'm looking quite forward to getting it and starting the install.
Old Feb 4, 2008 | 07:37 PM
zaptoad's Avatar
I loved the idea, but not the price. I couldn't afford to get everything I needed, so I ended up buildig my own. It's the same idea as putting a hitch on your truck, but at a different scale. The fine tuning can eat-up a lot of time though I found out, but it was a fun project. Its the time, research, and equipment that you are buying from Montana Jack's; not the materials. A side benefit, is that it makes your quad stronger too.
Old Feb 6, 2008 | 04:23 PM
JCDEYO25's Avatar
Well I guess you guys have a little more coin to spend than me......If you're looking for a 2 in. rear receiver it's not that hard to build one yourself.....I built this one myself modeled from the one from MJ's....Plus mine is 2in. and MJ's is only for 1 1/4 if I recall.....I kept mine as high as possible without having to remove my rear bumper....Check out my pics if you want here.
<a target=_blank class=ftalternatingbarlinklarge href="http://www.pbase.com/rottweiler/jcdeyo25
">http://www.pbase.com/rottweiler/jcdeyo25
</a>
John
Old Feb 18, 2008 | 09:30 AM
pat89's Avatar
I've installed my multi-mount and am really happy with it. It was a good time to replace some broken rack mounting bolts also. There was one problem I encountered with the rear half of the mount: my winch will not install properly with my HMF exhaust. You can flip it upside down and use it but this is, of course, not the ideal solution. I'm going to fabricate an extension to use to clear the exhaust. Other than that, it seems to be a great set-up.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Steeldon
Sep 9, 2015 09:38 AM
Cantbuytime
Aug 16, 2015 09:13 PM
toonces
Jul 21, 2015 02:40 AM
