350L only starts and runs with choke on, and hot light on all the time
Old Jan 31, 2008 | 02:34 AM
wizard1212's Avatar
Default 350L only starts and runs with choke on, and hot light on all the time
350l only starts with choke pulled and that is the only way that it runs????? Any suggestions? Also the hot light is always on even with the colant full?????
Old Jan 31, 2008 | 09:44 AM
Sandman2.0's Avatar
Well, I'd say that maybe your pilot jet is clogged. I'm not a Polaris expert but generally speaking, that is a symptom of clogged jets....usually pilot as it is really small and clogs easily.........had the same issue with my 330 trailboss.
Old Aug 22, 2012 | 06:32 PM
ATVoffroad1997's Avatar
Default polaris 350l will not fire up
hi everyone i am new to this but i figured this would be the best shot i have now i have many atvs and had many but they never were as confusing as this so someone please help
i bought this atv not running i was told it needed a crank seal but i looked farther into the atv it has a nice blue spark and it is gaped to the spec, it is getting plenty of fuel and i even cleaned the carb 2 to make sure it wasnt plugged up still wont start, so i finely changed the crank seal and still just wont fire i even took out the plug and cranked the motor with a peice of paper near cylinder head (purpose was to wet paper with fuel and see if it lites) it ignites so fuel wasnt the issue so i checked the last thing the piston which it is brand new rings are good and has 120 compression SOMEONE PLEASE HELP THANKS
Old Aug 23, 2012 | 07:26 AM
PLEASE! You've posted THREE times Twice in the normal threads and once in the expert section! Only one post is necessary in either section! OPT
whitty
67
Feb 24, 2021 02:52 PM
jayking232003
Jun 9, 2015 02:54 PM
garyt1975
Jun 5, 2015 08:53 AM
Steven Bandemer
May 27, 2015 07:39 PM
1000gade
May 27, 2015 12:37 PM
