reverse overide button
Old Feb 7, 2008 | 11:49 AM
markshop's Avatar
Default reverse overide button
Does the reverse overide button draw current when tie straped in and the key off? Its the only thing i did different and the battery was down. Or it could be all the plowing and winching and not driving it enough to charge back up. 07 800 sp
Old Feb 7, 2008 | 11:54 AM
itch's Avatar
i'm betting on the second one
Old Feb 7, 2008 | 04:21 PM
fredmartin94's Avatar
I have a 2002 400 Sportsman and have removed the reverse interrupter along with rewiring with an on/off switch for reverse. I have no battery problems and i use a electric lift,flasher & heated grips. I did change my battery to an AGM but its the same amps.
I would look into the wiring diagram and fix it so you have an on/off switch instead of the way you have it.
Old Feb 7, 2008 | 04:39 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
he cant just do away w/ the button as it scrolls thru the menu's in the speedo. your older 400 doesnt have that. im betting your winch killed the battery. put a switch in to bypass the button while in reverse like i did so you can switch back in forth and still be able to use the override scroll feature.
Old Feb 7, 2008 | 05:15 PM
Thats basically what i am suggesting. Wire tying the switch on isn't good especially if it does more functions. Do the newer models use the reverse interrupter yet? I got a warning from the police because of the noise. Thats what got me digging into the change and its great now.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
r1pilot83
Sep 27, 2015 07:38 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
