Timberwolf 250 puttering out
Old Feb 11, 2008 | 01:37 PM
thor's hammer's Avatar
Default Timberwolf 250 puttering out
Just signed up for the forum and I am pretty Clueless about off roading. I was given a 1996 250 2x4 Timberwolf and I have used it to go Ice fishing. I have developed a problem and I am sick of being stranded on the ICE.
Initially the machine starts and runs good when I have had the problem, it has been warmed up and working for 10 to 15 minutes when all of a sudden it makes this kind of popping backfiring noise and dies, then refuses to start untill I get it back to a warm garage, then it is like nothing happened.
Any clue on where I should look or adjustments I should make. Also, looking for a good wrencher in the Detroit area?
Sorry about the long post. Hoping that I can get a good direction on fixing the problem.
Old Feb 11, 2008 | 01:51 PM
Cmarti's Avatar
Gas Cap vent, and fuel shut off valve clean?
debris in fuel bowl?
Valve adjustment (Too tight when engine comes to temp?)
Believe it or not I had an intermitent problem and it was the cap vent. Yours seems to be when the engine reaches operating temp.
Good luck
Old Feb 11, 2008 | 01:53 PM
Cmarti's Avatar
I assumed above the choke/enrichener is operating and not froze on.......
Old Feb 11, 2008 | 02:08 PM
The enrichiner is not stuck and working properley. What is with the gas cap/vent. what should I check?
Old Feb 11, 2008 | 04:02 PM
Cmarti's Avatar
Tube coming off cap needs to be 3-4" high at the bend(tucks into hole on the ingnition switch cover), and vent hole in cap clear.
Old Feb 11, 2008 | 11:53 PM
I just went out side to try and start it I took off the gas cap and adjusted the tube. It started. The temp is 10 above zero. I warmed it up and tried to get it to quit. I could not.
Is there a test that I should try?
wildbill59
Jun 22, 2015 09:22 AM
wildbill59
Jun 9, 2015 02:28 AM
atc350
Jun 27, 2000 11:48 AM
95TimberWolf
Mar 14, 2000 10:33 AM
Brian_Kimmel
Aug 9, 1999 02:24 PM
