scrambler dont start
Old Feb 25, 2008 | 08:03 PM
trevortobe's Avatar
Default scrambler dont start
I have a 2003 scrambler that when I turn the key all it does is click. I replaced the battery and made sure i get power to the starter when the key is turned to the start position. I am unsure were I should look from here?
Old Feb 25, 2008 | 10:54 PM
dwhst9's Avatar
Have you measured the voltage at the solenoid as well and at the starter? The brushes in the starter could be stuck.
Old Feb 25, 2008 | 11:11 PM
ftwflh's Avatar
Try jumping around the solinoid and if that makes it crank the solonoid is bad if not it is time for a starter.
Old Feb 27, 2008 | 10:10 PM
trevortobe's Avatar
thanks for your help the brushes in the starter were froze up.
polaris scrambler00
Jun 20, 2015 08:49 AM
hoopduerr
Jun 10, 2015 03:00 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
1000gade
May 27, 2015 12:37 PM
