polaris magnum chain
Old Mar 2, 2008 | 12:18 AM
polaris man's Avatar
Default polaris magnum chain
how to adjust chain on 1998 polaris 425 magnum 2x4
Old Mar 2, 2008 | 12:22 AM
TxMagnum's Avatar
i saw this thread once maybe it will help
http://forums.atvconnection.co...11/threadid/460714.cfm
Old Mar 2, 2008 | 08:55 AM
ftwflh's Avatar
On the old non concentric models you loose the chinch bolts on the axle(5/8 in top and bottom)use a small punch to go through the sprocket into the axle housing(there is holes that will line up to do this)Use a tie down strap to compress the rear shock(I tie one end to the rack and the other to the hitch(this is a must to get the tightness correct.Now roll the atv one direction or the other to where the chain is just barlly snug.retighten bolts and loosen strap.It will look loose but when you sit on the seat it will tighten up.
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
Unzzy66
Jul 11, 2015 10:01 PM
jettman
Jul 6, 2015 12:16 PM
