polaris magnum chain
On the old non concentric models you loose the chinch bolts on the axle(5/8 in top and bottom)use a small punch to go through the sprocket into the axle housing(there is holes that will line up to do this)Use a tie down strap to compress the rear shock(I tie one end to the rack and the other to the hitch(this is a must to get the tightness correct.Now roll the atv one direction or the other to where the chain is just barlly snug.retighten bolts and loosen strap.It will look loose but when you sit on the seat it will tighten up.
