creep
Old Mar 11, 2008 | 07:30 AM
wayout's Avatar
Default creep
what makes a atv creep when you put it gear,my idle is about 1200,so it's ok......
Old Mar 11, 2008 | 07:40 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default creep
so wayout reading your signature, im assumimg your talking about the efi 500 now?? either the ebs bushing is bad, the clutches are out of alignment, or the bike is idled to high(not in your case if its at 1200 rpm). i have had a belt actually shrink once where it was too tight and made it creep.
Old Mar 11, 2008 | 07:52 AM
wayout's Avatar
Default creep
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
so wayout reading your signature, im assumimg your talking about the efi 500 now?? either the ebs bushing is bad, the clutches are out of alignment, or the bike is idled to high(not in your case if its at 1200 rpm). i have had a belt actually shrink once where it was too tight and made it creep.</end quote></div>
thanks,yea i'm talking about the 500efi,it's done it since i've own it,i have about 500 miles on it now,it's also hard to get in gear from low to high,it makes a sqealing noise all the time,a low pitch sound,and also it seems to vibarate more than it should,time to go to the shop i guess,thanks......
Old Mar 11, 2008 | 09:29 AM
RickCJ7's Avatar
Default creep
<div class="FTQUOTE"><begin quote>Originally posted by: wayout
what makes a atv creep when you put it gear,my idle is about 1200,so it's ok......</end quote></div>
The only thing to make it creep is the belt out of alignment!
Check your front engine mount if its not broke check the clutch alignment. My 500 had a busted engine mount and started to creep. Just take the belt cover off and look into the front pulley and make sure the belt is centered in the pulley.
If your mount is busted NAPA sells a replacement mount that is a lot stronger!
bvandass
Oct 8, 2015 09:13 AM
crazyoldfart
Jun 16, 2004 06:41 AM
RancherS01
May 31, 2004 01:25 AM
NovaKaw650
May 2, 2004 09:29 AM
HAMMERINHANK
Jun 7, 2003 10:45 AM
