POLARIS CARB
Old Mar 17, 2008 | 02:10 PM
allenduren's Avatar
Default POLARIS CARB
ok 99 scrambler 500 4x4.....
i pulled carb off and cleaned it and ever since it has been backfiring.....
what could be wrong did i loose or mis adjust the float.
when it back fires====i rev up and then let off and it backfires
what could it be????
Old Mar 17, 2008 | 02:21 PM
RickCJ7's Avatar
backfiring is from a lean condition, an intake leak or exhaust leak.
I'd double check around the intake and carb boot.
Old Mar 17, 2008 | 02:37 PM
allenduren's Avatar
alright will do later tonight when get home from work... it dont do it till its warmed up thats what i dont get
Old Mar 17, 2008 | 02:38 PM
allenduren's Avatar
exhaust leak will do it to then???? i did take exhaust off also maybe that could be it
Old Mar 18, 2008 | 12:04 PM
allenduren's Avatar
So exhaust leak will cause it to missfire then or what????
what are some other possibilitys it could be
Old Mar 19, 2008 | 11:08 AM
allenduren's Avatar
alright i rode the atv alot more last night and when you get on it for a longer period of time it will start to loose power and start stalling a little bit and the top end is nothing... you guys got any idea what i messed up on this machine???? kinda sux i put all the plastics on yesterday and they gotta come off know...... the intake boot is tight so it is something in the carb cuz i had it off..... i also aint sure if i got that main jet on the bottom of the carb clean cuz i didnt no it was down ther.... please get back to me with ideas of what it is
Old Mar 19, 2008 | 02:19 PM
WAATV's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: allenduren
when you get on it for a longer period of time it will start to loose power and start stalling a little bit and the top end is nothing...</end quote></div>
When I saw this condition on a carbed machine, it turned out that the float was set improperly. It was not letting enough fuel into the bowl, which starved the engine for fuel at higher throttle settings and yielded exactly the situation you describe. Perhaps you misadjusted the float while the carb was off?
Old Mar 19, 2008 | 03:14 PM
allenduren's Avatar
Thats what i kinda was thinking also.... now im gonna have to pull the whole damn thing down again grrrrrrrrrrr lol there a pain in da *** owell hahah this would mako backfire also wouldnt it
neilbedwell
Nov 10, 2018 11:02 AM
Ipmcelroy
Technical and How-To Articles
48
Nov 21, 2015 08:02 AM
Evan d
Jul 7, 2015 02:36 PM
gfl0224
Jun 27, 2015 06:52 PM
DOAinNY
Jun 11, 2015 10:34 PM
