crank seal on a 400 xplorer
Old Mar 19, 2008 | 01:18 AM
xplorerman's Avatar
Default crank seal on a 400 xplorer
i have a 1996 400 xplorer how do i check the crank seal on the clutch side and if it is bad how much truble is it to change
Old Mar 19, 2008 | 12:53 PM
xplorerman's Avatar
sorry can anyone help me with this
Old Mar 19, 2008 | 03:41 PM
BGRDTRUK's Avatar
Does it run now?
If not you will need to take off the clutch and look at it closely.
If it does run, spray carb cleaner on the seal while running and listen for a rpm change.
It's very easy to change if you have a clutch puller(special tool)and a seal puller.
Old Mar 19, 2008 | 06:20 PM
xplorerman's Avatar
Hello it still runs right just the revs stay up to long like a chansaw running out of gas i got a clutch puller from a buddy i cant fond a seal puller but if that is the problem i will make do thank you very much for the info i will try the carb cleener
Old Mar 19, 2008 | 06:43 PM
BGRDTRUK's Avatar
You can buy a seal puller at a auto Parts place.
(better yet rent or borrow one from autozone)
You can try the carb cleaner with the clutch on also.
Try choking it a little and see if that brings down the rpms also. It sounds like your a little lean for some reason.
Old Mar 19, 2008 | 06:53 PM
onesavage's Avatar
i have always just used a small screw driver and drive inbetween the houseing and the seal..works every time , as long as you do not beat the heck out of it you should have no damage..i work on auto engines for a liveing and i use this method alot,half of the seal pullers they want you to use do not work worth a crap..just mt 2 cents i never claimed to be right, i just get-er-done!!!
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 28, 2015 10:02 PM
Jackg17
Sep 26, 2015 09:30 PM
rockinkgin
Sep 25, 2015 01:52 PM
