How much play in the drive clutch?
Old Mar 24, 2008 | 11:23 AM
PolSports's Avatar
Default How much play in the drive clutch?
I started this weekend to try to fix my creeping issue. I looked at the drive clutch to see if the washers are worn but haven't got the pouller yet to actually pull the clutch. The belt is remaining in contact with the inner clutch sleave which is causing the creeping. The one way clutch the belt rides on has some play (side to side) in it. So I an assuming the washer between the one way clutch and inner sleave is worn therefore the belt is staying too close to the inner sleave and remaining in contact. Should there be any play at all in the one way clutch? Does this sound like I am on the right track? Thanks for all your help and Stendori it appears as though you are correct that I don't have a spring problem. Thanks!!
Old Mar 24, 2008 | 01:49 PM
hc's Avatar
hc
I just got my clutch back togather. I replaced both washers and both bushings. No play in the one way clutch on mine.
Old Mar 24, 2008 | 04:41 PM
PolSports's Avatar
Thanks! I am going to order new washers and hopefully the play will be gone along with the creep.
Cummins Driver
Sep 11, 2019 01:22 PM
mdigitale
Aug 6, 2015 12:35 AM
ghost civic
Jul 15, 2015 10:48 PM
clsharky
Jul 13, 2015 02:07 PM
tporath
Jul 11, 2015 12:31 PM
