Location of Oil Filter on 1984 Honda ATC Big Red w/Reverse
I've got a "duh" question. I retrieved my old Big Red from deer camp after it has set idle for many years and I'm getting it back in running condition. My problem is I can't remember and can't find the location of the oil filter.
Can anyone give me a clue where to look?
If it is a 200, no filter
If it is a 250, side of the engine there is a cover about 2 1/2" in diameter with 3 bolts holding the cover on (8 mm socket fits them). Take note that one bolt is shorter than the other 2 when you reinstall the cover
----- Gimpster -----
The 1984 ATC200ES BigRed has an oil screen under the 24mm oil drain plug .. It also has an oil rotor on the end of the centrifugal clutch , the clutch cover must be removed to clean it ..
Since I'm talking to the experts, what grade of oil do ya'll recommend?
Hey, thanks, guys:
My first time on this forum and your responses were great! I'm sure I'll be checking back in before I get the ole Big Red back in the woods.
Thanks again!
Thanks again!
