Location of Oil Filter on 1984 Honda ATC Big Red w/Reverse
Old Mar 28, 2008 | 09:05 PM
Thurman1's Avatar
Default Location of Oil Filter on 1984 Honda ATC Big Red w/Reverse
I've got a "duh" question. I retrieved my old Big Red from deer camp after it has set idle for many years and I'm getting it back in running condition. My problem is I can't remember and can't find the location of the oil filter.
Can anyone give me a clue where to look?
Old Mar 28, 2008 | 09:43 PM
Gimpster's Avatar
If it is a 200, no filter
If it is a 250, side of the engine there is a cover about 2 1/2" in diameter with 3 bolts holding the cover on (8 mm socket fits them). Take note that one bolt is shorter than the other 2 when you reinstall the cover
----- Gimpster -----
Old Mar 28, 2008 | 09:45 PM
HondaMechanic's Avatar
The 1984 ATC200ES BigRed has an oil screen under the 24mm oil drain plug .. It also has an oil rotor on the end of the centrifugal clutch , the clutch cover must be removed to clean it ..
Old Mar 28, 2008 | 09:49 PM
Gimpster's Avatar
Thanks for the correction, bud
I was thinking 250 big red
I corrected my initial post
----- Gregg -----
Thurman1's Avatar
Thanks, HondaMechanic!
So, the only "filter" is the oil screen in the drain hole?
Old Mar 28, 2008 | 09:51 PM
Thurman1's Avatar
Yeah, Gimpster, it is a 200. I should have included that in my initial post.
Thanks for you help!
Old Mar 28, 2008 | 09:57 PM
Thurman1's Avatar
Since I'm talking to the experts, what grade of oil do ya'll recommend?
Old Mar 28, 2008 | 11:44 PM
Gimpster's Avatar
I normally use the Honda GN4 10w-40. Good for most operating temps
Old Mar 29, 2008 | 10:47 AM
Thurman1's Avatar
Hey, thanks, guys:
My first time on this forum and your responses were great! I'm sure I'll be checking back in before I get the ole Big Red back in the woods.
Thanks again!
lightninboy
May 16, 2021 09:52 PM
ScopeZ_
Jul 28, 2015 01:44 AM
kdg723
Jul 25, 2015 01:20 PM
hondarider1234
Jul 21, 2015 11:53 PM
timster911
Jul 13, 2015 01:57 PM
