Moose winch clutch problem
Old Apr 2, 2008 | 02:31 PM
Totalboard's Avatar
Default Moose winch clutch problem
I purchased my 2007 Rancher 420 last year and had the dealership order and install a winch for it. They
said the 1700# Moose was what Honda recommended because of the limited space for
the winch. I used it for lifting and lowering the snow plow but if I use it for pulling, I cannot disengage
the clutch on the Moose because the lever is restricted by either the plate or the frame so I have
to extend the cable with the motor.
Has anyone else had this problem with this model of Moose or is there an easy fix?
Thanks,
Randy
Old Apr 2, 2008 | 05:48 PM
Gimpster's Avatar
You could try unbolting the winch from the plate. install it with the motor end of the winch on the other side of the quad. You will have to unspool all the cable and respool it so your in and out direction on the switch is correct
----- Gimpster -----
skinnyr6
Aug 25, 2023 02:18 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
honda71
Jul 12, 2015 05:56 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
