Rancher 350
Old Apr 3, 2008 | 11:02 AM
scottyp's Avatar
Default Rancher 350
I'm trying to take the gas tank off to clean it out. I can see sand and dirt in the bottom of it. I've drained it, taken off the 3 screws and the plastic cover over the top where the cap goes. My question is this: It's loose and wants to come off but the fuel on/off/reservoir **** is in the way. Is there a way to take the **** off? I don't need to remover the rest of the cowling do I?
Wanted to ask people who know more than me before I start bowing up on it and break something..............
Thanks!
Scott
Old Apr 3, 2008 | 03:17 PM
Gimpster's Avatar
Default Rancher 350
Scott, use a longer phillips screwdriver in the center of the fuel valve ****. Normal phillips screwdrivers can be too short to reach the head of the screw on some models.
When installing, notice that where the **** slips over the petcock shaft that all 4 corners of the square shaft are not square. One is rounded. Same inside the fuel ****. This is to index the **** for proper on, off and reserve indication when properly installed.
----- Gimpster -----
Old Apr 3, 2008 | 03:28 PM
scottyp's Avatar
Default Rancher 350
Thanks, Gimpster. I didn't know there was a screw up in there. That helps tremendously. And, yes, I will need a longer than normal.
Thanks Again,
Scott
ps Any suggestions on how or what I should use to rinse out the tank to get the junk out of there? Like I said, it looks like sand and I'm pretty sure it is since I've been riding it in Florida the last few years............
Old Apr 3, 2008 | 07:47 PM
Gimpster's Avatar
Default Rancher 350
Well, you will have to remove the petcock assembly. If you try to flush the tank and hold it upside down, you will not get everything out. There is a lip inside the fuel filler opening...
Probably water and repeat shaking and emptying until everything is out. I usually pressure wash them inside unless something is sticking to the bottom where I will drop a rag inside and with a long object, rub it around to break it loose. Has been times where I had to dump BB's in the tank and shake it to break stuff loose. And then you will have to totally let the tank dry after having water in it.
That is about all I can suggest other than taking to a radiator shop and have them steam clean it.
Old Apr 4, 2008 | 03:04 PM
scottyp's Avatar
Default Rancher 350
Thanks again, Gimpster. You've been a tremendous help.
Have a great weekend!
Scott
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
Elkaholic
Sep 6, 2015 02:44 PM
