stiffen suspention
Old Apr 6, 2008 | 11:28 PM
Spman 800's Avatar
Default stiffen suspention
can you stifen your suspention to to get more clearece on a 800 if so how much do you get
Old Apr 6, 2008 | 11:40 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
You can put spring rubbers in between the coil springs......Most use this for plowing though with the extra weight of the plow and bracket mounted to the front of the Quad.....As for the rear you should have a adjustment on the rear .....turn the plate that puts more of less pressure on the coil spring!!..........As for just the front others may give you more ideas!!.......Caper......
Old Apr 6, 2008 | 11:42 PM
Spman 800's Avatar
thanks caper
Old Apr 7, 2008 | 12:07 AM
sprinter10's Avatar
i snow plow with my scrambler and i have teh spring rubbers and on the scrambler they berily do anything i sping them all of the way to the top and i see them hilping a lil bit when i am off the quad and rais and lower teh plow but when im on it i don't feel a diff at all maby the sportsman springs are coiled closer together and they spred the coils out a lil.
Old Apr 7, 2008 | 06:52 AM
upnort's Avatar
Have found those rubber spacers that go between the springs to be useless. Have a set in a box somewhere that I tried & packed away. Some have gone with heavy duty springs from the ranger. Also there are spring spacers that go under the springs, some adjustable, That increase the preload.
Old Apr 7, 2008 | 07:01 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
your going to have to ad spacers or a lift to get more clearance.
Old Apr 7, 2008 | 01:47 PM
MECHANIKE's Avatar
HIO,I STARTED RAISING THE SCRAM WHEN I WAS CHECKING FRONT BEARING PRELOAD+ I NOTICED SOME PLAY IN ONE FRONT SPRING,NOTICED THE BOTTOM SPRING SHIMS MISSING,ME BEING A OVERENGINEERER DECIDED TO ADDING XTRA SHIMS,TWO IS STOCK SO ADDED 5.IT RAISED THE FRONT END A ".ALSO NOTICABLE STIFFER.SO I KEPT GOING +SCREWED UP THE REAR MONO ALL THE WAY + IT WENT UP+ BECAME STIFFER BUT NOT TONS,FOUND A HUGE ENCASED BEARING LYING AROUND PUT IT ON TOP OF THE SPRING.BROUGHT IT TO THE TOP OF THE TRAVEL,WHEN YOU SIT ON IT THE REAR DROPS DOWN 2" NOT THE USUAL 6
Old Apr 7, 2008 | 08:00 PM
Spman 800's Avatar
i dont want to get more lift i just dont want it to sag so much. after a whel of rideing they will start to sag
Old Apr 7, 2008 | 11:15 PM
RickCJ7's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Spman 800
i dont want to get more lift i just dont want it to sag so much. after a whel of rideing they will start to sag</end quote></div>
I just removed the Polaris HD front springs off my 500, they will fit your 800!
$40
thunderpower
Aug 25, 2003 07:26 PM
thunderpower
KTM
12
Jan 23, 2002 02:31 PM
Robwes85
Jul 13, 2001 07:34 AM
offroader0794
Jan 1, 2001 04:31 PM
ZoinksOldID
Oct 29, 2000 12:56 PM
