Stock banshee suspention
What would be a good stock suspention setup for a banshee? How many clicks for compression and rebound also what spring tension. Im 130 pounds I ride on an MX track I get about 10 feet high and 40 feet far. Thanks I dont know much about suspention and any info could help. Thanks
Suspension has to be setup to your own liking, Everyone likes it set different. Just start where the factory set and adjust from there. Only adjust 1 adjustment at a time too. It will probably take a few hours to get it set right for you. For doing jumps your suspension should be setup to LIGHTLY bottom out off of the biggest jump you can do, Unfortunatly, by setting it up like this if you land wrong you will use up all your suspension and probably crash <ouch> !! Something most people overlook is air pressure in your tires, It affects your suspension and is actually part of it.
