warrior help
Old Apr 14, 2008 | 11:54 AM
WARRIOR360's Avatar
Default warrior help
i know what im getting myself into so pleas dont say dont modify a warrior i just want to know if i got these upgrades if they would be good up grades
white brothers e2 slip-on exhaust, k&n airfilter, fmf jet kit, stage 1 hot cam,
20" kenda klaw rear tires
i already have the head port and polished and is bored to 360cc
Old Apr 14, 2008 | 12:04 PM
pmcc37's Avatar
I have a stage one Hotcam, It's ok for mild use, but I'm looking into pulling it and going with a diffrent one, either webcam or DR X1 grind cam, and putting the hotcam in my bigbear...
You don't need a jet kit, its cheaper to buy one jet main jet at a time and see what works best... 148 (147.5) or 150 will most likely fit your application...
Old Apr 14, 2008 | 03:52 PM
TomM's Avatar
Here comes one of those lengthly cam argument threads. Ill go ahead and start it. I went with the stage one Hotcam, it made a small but noticeable power increase at high rpm. I am happy with it for 130$ and under 2hours work. However if I had it ported and polished and/or was going to put more time and $s into it I would more likely go with a different cam. I dont want to put big $s into a Warrior especailly an old one like mine. I save most of my $s for a newer faster quad. I also went with a painted Cobra exhaust which Im not dissapointed with for 138$ and use a filter of my own design instead of the expensive K+N.
Old Apr 14, 2008 | 03:58 PM
TomM's Avatar
The quiet Cobra exhaust not the loud one.
Old Apr 14, 2008 | 04:19 PM
pmcc37's Avatar
i had my head ported n polished, n think my bike should make more power, however the hotcam does it's job, plus i already had it.... i may go diffrent, but with a stock setup its a better cam than with a more built setup..... IMO
Old Apr 14, 2008 | 04:21 PM
pmcc37's Avatar
oh n the conra exhaust (load) off my 01 that was stolen felt to make more power than my fmf, however it was stock..
Old Apr 14, 2008 | 08:34 PM
Raptor450's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: WARRIOR360
i already have the head port and polished and is bored to 360cc</end quote></div>
My opinion: The e-series exhaust doesn't sound that great. They seem to perform pretty good, though. I still believe in the $220 slip-on HMF for the Warrior. Everything else you have is OK, except the stage one cam. At least try to get the stage 2, but preferably the .430" Webcam is the way to go.
On mine I had a P&P head, bigger valves, and the .430 Webcam with a stock piston and in ran real good. I thought the cam would be too much for the piston, but it did fine. 2 weeks later I installed the JE 366 kit. If you do this a 14 tooth front sprocket would be a good choice also.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
