Rancher 350 maintenance
Old Apr 15, 2008 | 10:09 PM
rhonda350's Avatar
Default Rancher 350 maintenance
I have a 350 rancher what else can i do besides oil change, new spark plug, clean airfilter, new oil filter, and valve ajustment to keep my bike in tip top shape.
Old Apr 15, 2008 | 11:14 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Change oil in the front and rear drives once each year.
Old Apr 16, 2008 | 12:51 AM
Gimpster's Avatar
Few other things
-Check all cables and controls for proper adjustment and freedom of movement
-Adjust front and rear brakes
-Set tire pressures
-Lift the quad and check wheel bearings and swing arm pivots for looseness
-Check the charging system
-Check differential breather hoses
-Adjust the fuel air mixture screw on the carb
-Check ball joints, boots and tie rod ends, and their boots
-Check steering column pivot bushing upper and lower bearing
-Look under the housing recoil for oil seeping
-Feel the boot between engine and swing arm (Make sure it is not soft from a rear engine seal leaking)
-Pull the air box drain/trap empty it and clean
----- Gimpster -----
Johnny Mac
Aug 15, 2019 03:13 PM
dannytas
Sep 26, 2017 06:31 PM
Clint Russell
Sep 25, 2015 03:20 PM
cboler9
Sep 24, 2015 08:35 PM
rgjackson
Sep 17, 2015 11:21 AM
