FRONT CVD
Old Apr 16, 2008 | 06:44 PM
dogspower1's Avatar
Default FRONT CVD
just wanting to find out the best way to get the roll pin holding the axle in on a xplorer 400 looks like it could be a pain in the rear
thanks
Old Apr 16, 2008 | 10:12 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default FRONT CVD
roll pins are a pain sometimes. just get a matching size punch to hammmer it out with. maybe a little penetracting oil if its been in there awhile.
Old Apr 16, 2008 | 11:04 PM
Ujoint's Avatar
Default FRONT CVD
We use a long tapered punch from the front of the quad to get the pin started - gives some swinging room... then, once the pin starts moving, use a short 1/4" pin punch (worse comes to worse, a 1/4" bolt will do too) to finish driving the pin out.
When you go to put the axle back on, start the pin in the yoke's hole first, then use a 1/4" bolt on the "open hole" side to help line up with the hole in the shaft, rotate the shaft where you can get a hammer to it and drive the pin back in.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
