clutches
Old Apr 17, 2008 | 12:34 AM
slinky-1979's Avatar
Default clutches
hello to all. just wonding if anyone has adjusted the secondary clutch on a polaris 2 stroke ? and if so how
Old Apr 17, 2008 | 01:36 AM
Kerbbirds's Avatar
Default clutches
only way to do that if it is a non ebs four wheeler is to change the position of the spring and rewind it and see what it does
Old Apr 17, 2008 | 07:49 AM
ftwflh's Avatar
Default clutches
THe only secondary clutches without adjustment are the roller clutches.
You can set the spring tension for better back shift,better excelleration and to fine tune rpms.But with each change it effects other things.
Old Apr 17, 2008 | 09:39 AM
Default clutches
thanks for the advice, i will let u know what the out com is . and once again thanks
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
