front breaks scream/grind
Old Apr 17, 2008 | 02:20 AM
nightmare0098's Avatar
Default front breaks scream/grind
any sugesstions? beside new shoes obviously. lol
Old Apr 17, 2008 | 09:28 AM
P1FOXRIDER's Avatar
in '03 yamaha put hydrolic brakes on the blaster, they are a lot like the ones on raptors, if the are hydrolic brakes then the pads are worn out and you need new ones
Old Apr 17, 2008 | 03:42 PM
how can i tell if they are hydrolic or not?
Old Apr 17, 2008 | 06:44 PM
Mlarkin_09's Avatar
on the right hand side of the handle bars there should be a rbake fluid resevoir mounted on the brake handle. If its a 2003 its hydro. I would check and see if you have pads remaining on there thats most likey your problem . Although if its grinding all the time you could have something like a rock wedged between the rotor and caliper. Bearing locking up. But start simple first
Old Apr 18, 2008 | 02:58 AM
i was told it was a 2003 when i bought it.. but there is no fluid resevoir. no place to put break fluid anywhere on the whole quad..
Old Apr 18, 2008 | 09:51 AM
faponce's Avatar
Then you don't have an 03. you can get an exploded view of 03 blaster front breaks at the following, it has a standard handle bar fluid resevoir.
http://www.cheapcycleparts.com...wbybrand/2/Yamaha.aspx
Old Apr 18, 2008 | 09:35 PM
how do i find out what year it is then?
Old Apr 19, 2008 | 09:29 AM
faponce's Avatar
Find the VIN number on the frame and call a local Yamaha dealer.
Bratman2
Aug 6, 2022 01:42 AM
TLC
Jul 25, 2015 02:24 AM
clsharky
Jul 13, 2015 02:07 PM
Unzzy66
Jul 11, 2015 10:01 PM
tporath
Jul 11, 2015 12:31 PM
