help 200 es problems
Old Apr 18, 2008 | 08:06 PM
bcjamz's Avatar
Default help 200 es problems
ok guys and gals here is the scoop, first great web site. Now on to the hard stuff i just bought a 200es 1984 and the old boy said it has no spark. first off checked out all the old reliables, plug wire good, plug seem good, juice coming from stator and pulse generator. Now here is the crazy part 2 days ago no spark on the plug but!!!!! when you use the multimeter to check the plug wire and igition coil they are pumping out 12+ volts check the end of the plug nothing. played with it today actually had it fire twice but had gas tank off so it didnt last long enough to test any thing. now nothing this is whippin my but. I just want it to run as good as my 83 big red or even half as good OK just get it to run then ill worry about the rest....... thanks in advance
Butch
CPO, USN, active duty
and no i ain't gonna press 1 for english
Old Apr 18, 2008 | 10:35 PM
sdm111's Avatar
2 strokes or 4
From what you say sounds like you need a new plug wire. Or maybe crimp the end a bit through the insulation with pliers and get a new plug, if it reads 12 everytime.
Old Apr 19, 2008 | 11:58 AM
atc200m's Avatar
the plug may not be touching the inside of the plug wire and that could cause a bad spark
Old Apr 20, 2008 | 06:23 PM
bcjamz's Avatar
well guys i got peeved today and started tearingthe whole thing down and walk thru the whole electrical system . took off seat all plastics and had a hammer on standby. pulled the regulator and had one complete wire corroded thru... its alive had is running for all of 45 seconds but it was strong!!!!!!!! were gettin there thanks for all the help[ will keep posts coming
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
