05 rincon
Old Apr 21, 2008 | 12:06 PM
smeagle 99's Avatar
Default 05 rincon
i have a 05 rincon,i installed a dynojet kit with k&n filter.the kit came with a after market spring.my question is will i gain anything by clipping the after market spring or do i leave it alone.
i would like to get a little more low end response.any ideas?
Old Apr 23, 2008 | 07:55 PM
kfdjason7620's Avatar
Default 05 rincon
depends on which jet you installed, and dynojets tech support can be a big help
Old Apr 24, 2008 | 11:17 AM
smeagle 99's Avatar
Default 05 rincon
THANKS I will try them & check my jet size.Think a pipe will help and do they make 1 thats not screaming loud,i still use it hunting.
Old Apr 24, 2008 | 05:30 PM
Default 05 rincon
the pipe will change the rincon into a totally different ride. but it is louder, but they also make a stealth kit that slips on to make it back quiet when you want. i got mine jetted, k&n filter, pipe and i also lifted mine 1.5 inches in the front to make it sit level. now, no lie i weigh 225 pounds and can sit on the gas cap and still pop wheelies. another tip is that i am very particular about mine, so no gas out of a jug, only the gas nozzle at the store, and only 93 octane. also use the "Engine Ice" coolant. your fan will hardly ever run. cooler engine = more power. and maybe 1 gallon of 110 octane every 4 tank fulls. not to often b/c its leaded, and could burn a piston if too much but 1 gal wont hurt, just runs better and smells good.
Nondem
Feb 22, 2020 12:20 PM
neilbedwell
Nov 10, 2018 11:02 AM
Norseman
Apr 7, 2002 07:50 PM
Recondude
Nov 13, 2001 08:24 PM
YZGUY
Sep 21, 2001 10:12 AM
