96 explorer 300 front is turning sharp and fast while driving not abrake
Old Apr 26, 2008 | 12:40 AM
mudding's Avatar
Default 96 explorer 300 front is turning sharp and fast while driving not abrake
i bought this quad the other weekend and it worked great. I now have a problem the front is turning it feels like the 4x4 is engaging when it is in2wheel it does not do it all the time but when i gas it it will kick to the left hard. the chain in the rear is normal when it is working fine then when it kicks it is very tight. when i jake it up the back and the left tire the side it goes to when this happens are turning. please help
Old Apr 26, 2008 | 07:06 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
maybe that hub is locking up on it. try changing the hub fluid on both.
Old Apr 26, 2008 | 07:19 AM
mudding's Avatar
thanx i will give it a try
Old Apr 26, 2008 | 08:57 AM
Ujoint's Avatar
Changing the Hub fluid is the quickest, easiest thing to try. If this does fix the problem, then I would say the key words are "but when I gas on it" - probably means the garter spring on the Hillard clutch in that hub is weak, allowing centrifugal force to kick the rollers out on hard acceleration.
MikeyBoyesq
Nov 27, 2020 02:44 PM
txkevin
Sep 21, 2015 02:02 PM
Shooterj2003
Jun 21, 2015 07:51 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
Tornado
Aug 1, 1999 12:08 AM
