05 660 raptor at full throttle reverse liket flickers and feels like is up against the rev limiter? any help would be ar
Old May 4, 2008 | 12:27 PM
drillerrich's Avatar
Default 05 660 raptor at full throttle reverse liket flickers and feels like is up against the rev limiter? any help would be ar
hi this bike has never had any problems super fast and reliable ... we went to the dunes in april and this appeared after a couple of days not sure any help would be apreciated
Old May 4, 2008 | 08:16 PM
StngGT350's Avatar
oh i had this happen to my Raptor in the middle of the mountains. look at your left side of your bike near the break. there is a electrical connection (boot) going to the case. well pull it off and check it, clean it out and blow it out. i beleive that is yoru reverse sensor, not too sure. but i ran mine through a creek while back and it was doing that. i also cleaned and blew out connections on my CDI box which is under your seat. but i am most positive that might be that boot connector. but one of these two should correct your problem.
good luck!
Old May 4, 2008 | 09:23 PM
Slaxxor's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: StngGT350
</end quote></div>
Yup, that is the reverse sensor wire and most likely the cause of your problem. If you ground that wire to the frame it will disable the reverse limiter (and reverse indicator light) and fix this problem permanently.
skinnyr6
Aug 25, 2023 02:18 AM
Reactant
Mar 30, 2022 02:08 AM
Ramman1
Jun 16, 2016 09:07 PM
blpersinger
Jul 15, 2015 09:56 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
