05 660 raptor at full throttle reverse liket flickers and feels like is up against the rev limiter? any help would be ar
hi this bike has never had any problems super fast and reliable ... we went to the dunes in april and this appeared after a couple of days not sure any help would be apreciated
oh i had this happen to my Raptor in the middle of the mountains. look at your left side of your bike near the break. there is a electrical connection (boot) going to the case. well pull it off and check it, clean it out and blow it out. i beleive that is yoru reverse sensor, not too sure. but i ran mine through a creek while back and it was doing that. i also cleaned and blew out connections on my CDI box which is under your seat. but i am most positive that might be that boot connector. but one of these two should correct your problem.
good luck!
good luck!
<div class="FTQUOTE"><begin quote>Originally posted by: StngGT350
</end quote></div>
Yup, that is the reverse sensor wire and most likely the cause of your problem. If you ground that wire to the frame it will disable the reverse limiter (and reverse indicator light) and fix this problem permanently.
</end quote></div>
