Which Timing Marks?
Old Jan 21, 2001 | 10:19 AM
snakeyes93's Avatar
hi,
once again i need the help of the great people in atvconnection.com my question is that when i went to set the engine on TDC i noticed there were a couple marks on the flywheel. one mark has a T stamped right beside it( guess that would be TDC but there were a couple(2-3) marks just ahead of the T mark. what do those marks before it mean? i've heard that engines should fire a couple degrees before TDC, is that what these are for? basically what marks do i use when setting the timing? thanks for all the help on this long process.
Old Jan 21, 2001 | 11:44 AM
springdrl's Avatar
If these are true marks on the flywheel, they are probably degree marks that are used for timing the spark. In other words, they indicate a given number of degrees before TDC.
The TDC mark is best used to adjust the valve tapping clearances which are always referenced to this mark.
Old Jan 21, 2001 | 02:28 PM
Diogenes's Avatar
Apparently you didn't read my response on your other topic; I won't repeat myself here. Good luck!
Diogenes
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
