1980 Honda 110 3 wheeler
Old May 6, 2008 | 01:56 AM
Wheels_17's Avatar
Default 1980 Honda 110 3 wheeler
Help...Question has anyone run into this.
I have a 1980 Honda 110 3 wheeler that occasionally runs? I get spark, fuel appears to good I even tried starting fuild into the carb and cylendar and sometimes it starts and runs strong no problems however after sitting for awhile I try to start and no luck my shoulder is sore. Is there a trick starting?
The rubber fitting from carb to airbox is missing. However I read somewhere people where taking them off and getting better perfomance. I wonder if this is the problem maybe the engine needs the restriction when starting? does anyone know? Any insight would be appreciated.
Thanks,
Old May 8, 2008 | 12:30 AM
Basstromboon's Avatar
Well could be a few things. Could be getting too much air/not enough fuel. I bought a cheap radiator hose for a car and cut it in half...works better than most hoses made to fit. Have you cleaned the carb? If not...its a must. I also suggest an inline fuel filter. I never drive my bikes on reserve just to be safe. Could be a few other issue but those are the most common. Try choking/half choke. If it will not start unless you use starting fluid, its prob a dirty carb. Best wishes.
Old May 8, 2008 | 11:26 AM
scary132's Avatar
So you have no air cleaner at all, just an open carb? I agree, your carb definately need to be cleaned plus its probably lean. Performance gain?? Sounds like the opposite to me. Put the airbox back together and with an airfilter.
Old May 9, 2008 | 04:25 PM
Wheels_17's Avatar
Thanks for input - over the next week I plan on pulling the Carb and giving a good cleaning. Also I will order pickup a hose to hookup the airbox.
Thanks again I will keep everyone posted on the outcome.....
Old Jun 22, 2008 | 08:31 PM
Zakry1983's Avatar
i have the same problemb with my atc110 but i have no idea of how to pull a carb
Old Jun 24, 2008 | 03:11 PM
Wheels_17's Avatar
First changed the spark plug - started then to be safe I cleaned the carb and hooked up the airbox it's running great....
Thanks again.
Old Jun 24, 2008 | 03:19 PM
Wheels_17's Avatar
Change Spark first, verify spark, then consider cleaning the carb. I also recommend getting Clymer Service Manual.
Good Luck!
RickyMac
Mar 5, 2016 07:27 AM
bigred20653
Aug 31, 2015 12:41 PM
stendori
Aug 14, 2015 12:57 PM
mdigitale
Aug 6, 2015 12:35 AM
HondaR24
Jul 16, 2015 10:45 AM
