Need help with my Recon please
Old Jan 21, 2001 | 04:23 PM
Hondapride's Avatar
Ok here is my story.
I have a 1998 Recon and I run into problems when I try to cross water that is about 3 inches over the foot pegs. My Recon stalls and is difficult to start again. I thought ok this is easy to fix so I re-routed the carb breather hose farther up the frame and have had no further problems. Just a little while ago I went to go clean my air filter and noticed that there was quite a bit of gas in my airbox about 2 inches. So I figured that it was because I re-routed my carb hose(the carb hose is not routed to the airbox) So I put the carb hose back to its normal position and went out for a ride, upon my return I checked the airbox again and to my suprise there was still a rather large amount of gas at the bottom of the box. I looked at the carb and noticed that there was gas dripping off the bottom of the outside of it. And thats where my lack of knowledge on atv carbs stops me from solving this problem myself.
If anyone can help me with these two problems (deep water crossings & carb leakage)than thank you very much!!!!
Hondapride
1998 Honda Recon Sur Traks mounted on Itp aluminum ,Uni air filter.
www.geocities.com/hondapride_98
Old Jan 21, 2001 | 08:45 PM
zeebo's Avatar
I had the same problem woth my recon with the deep water crossing . on the very top of the carb were the throttle cable goes in pry back the little rubber peice and put some silocon **** around it then slip the rubber peice back over the wet silicon and let it sit for at least 24 hours . then your problem should be fixed!
Recon
supertrapp ids 2 pipe
nerf bars
K+N jet kit
Renthals
Scott grips
K+N filter + outerwears cover
Bored out to 300
custom fender job
Old Jan 22, 2001 | 11:16 AM
Hondapride's Avatar
Thanks for the info I will have to try that, but how did you fix your deepwater crossing problem?
Old Jan 22, 2001 | 08:06 PM
zeebo's Avatar
that is how you solve that problem
Old Jan 23, 2001 | 07:04 PM
Hondapride's Avatar
How does that stop water from being sucked up my breather hose though??
Hunter100us
Oct 7, 2015 11:46 PM
peytonius
Sep 28, 2015 02:18 PM
Jason Campbell
Sep 7, 2015 02:25 PM
Hondamx751
Aug 13, 2015 01:06 AM
MNatv89
Aug 10, 2015 02:20 PM
