reverse broken?
Old May 9, 2008 | 04:17 PM
tja349's Avatar
Default reverse broken?
again issues with the 200cc redcat that i recenlty purchesed.... the reverse has worked but now its not catching -- the chain moves but its not locking with the axel
---any info appreciated.
Old May 9, 2008 | 05:21 PM
outofline's Avatar
But it goes forward ok? is this a automatic (no gears) and has a black box mounted to the rear axle?
Old May 9, 2008 | 07:21 PM
tja349's Avatar
its a has a clutch and i think 4 gears but yea forwards works fine.... it has trouble goin in to 1st some times (know anyting about that?) you just have to shift up sometimes then down to get it into 1st or just beat it around a little..... as for the reverse like i said b4 it worked a few times but then stopped -- it was kind of progressive it worked -then worked and would slip out -then just doesnt work
Old May 9, 2008 | 09:27 PM
outofline's Avatar
But you say you put it into reveres and let the clutch out and you see the chain go around but the ATV goes nowhere? The rear sprocket is attached to the axle so if it goes forward it will also go back. Or does the chain just tighten a bit buy really does not move when you try to go back? How ever it does not sound too good and most likely is a bad reveres gear I'm guessing. Is this band new or used when you bought it. You can live without a reveres gear although the gear pieces are lying around inside there. The whole finding first does not sound too good. I would make sure your clutch cable is adjusted properly and replace the oil and see if that makes it easier to find first.
Old May 9, 2008 | 10:39 PM
tja349's Avatar
no it doesnt just tighten it spins around but ya its not a real big deal.... just change the engine oil you mean? and where do i adjust th clutch cable-- just on the lever? and i bought it used from some shady character but you cant win thm all i gues -- live n learn eh? it was cheap at least -- by the way Lets go pens!
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
poutlaw525
Sep 9, 2015 03:19 AM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
