reset belt light
Old May 17, 2008 | 03:42 PM
plater1's Avatar
Default reset belt light
i was wondering if some one could tell me where the wires are located on a 06 brute force 750 to reset the belt light and the steps invollved. info would be greatly appreciated.
Old May 18, 2008 | 07:17 AM
contentsunderpressur's Avatar
The wire is right above the belt box. You unplug them and plug the thing into it and turn the key on. I'm not 100% sure on this though because it's been a long time since I've had to reset one of them. I think the light will flash a few time though and you turn the key back off and plug the wire back in. Maybe someone that has done this recently will chim in though. Good luck.
Old May 19, 2008 | 08:08 PM
trailblazermudrunner's Avatar
is this the same on a p360?
Old May 19, 2008 | 08:31 PM
It should be the same on all belt driven Kawi engines.
Old May 19, 2008 | 08:33 PM
okie i see a post on here of a diogram that showed how to do it some one scaned on here and had step by step instructions
opps mi bad i see it on a diffrent fourm ill put a the websit up for u so u can see the instruction page
let me know if this works
Old May 20, 2008 | 01:41 PM
plater1's Avatar
just letting you know that worked great, the pictures and description is perfect.
thanks
Old May 20, 2008 | 02:51 PM
KMKjr's Avatar
Unplug then 2 wire connector at the belt housing. Turn key back and then separate the grey connector under the seat, unplug the black connector, plug the matching connectors from the grey into the black. Turn key ahead and should flash fast then stop. Plug in 2 wire connector at cover, turn key off, plug in grey and black back to orginal the turn key ahead. Light should be out.
All right here in detail:
http://www.mmi.org/merrington/...uteforceshopmanual.pdf
Old May 21, 2008 | 12:17 AM
ur link didnt work
Old May 21, 2008 | 08:31 AM
KMKjr's Avatar
Sorry, try this:
Old May 21, 2008 | 09:43 PM
this one worked does ne one have one of thoes for a 03 p360
speedbuff
13
Nov 11, 2020 10:16 AM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
stcspiderman
Sep 13, 2015 05:15 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
