'05 650 V2 Idle Problem
Old May 17, 2008 | 08:58 PM
Tomhusker's Avatar
Default '05 650 V2 Idle Problem
Hi all,
I bought the 650 V2 last week and it rides great. The only problem is, once it warms up, it does not idle. There are no starting issues, as it fires right up every time, and as long as I give it a little throttle, it'll stay running.
The PO said he had some work done on the choke last winter, though I can't tell any difference in the RPMs with the choke opened or closed.
I bought it to haul my ice fishing gear in the winter, so I have time to get it fixed, but I am not real sure what to look for. Is there an idle adjustment screw somewhere that is accesible?
Old May 21, 2008 | 12:07 PM
Tomhusker's Avatar
Really? 50 Views and nobody has an answer on this? [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 21, 2008 | 12:40 PM
tancat500's Avatar
I am not sure about your bike, but mine has an idle adjustment **** right behind the carb. easily accessible from the right side while sitting on the bike! Good luck man!
Old May 24, 2008 | 02:49 PM
motrapperjohn's Avatar
How many miles does it have? Might check the valve adjustment, if the idle dont help. Usualy if the valves are tight it wont idle and is hard to start once warm.
Old May 25, 2008 | 10:04 PM
Sindelir's Avatar
Its neither valve adjustment or idle adjustment, your choke is sticking causing it to start fine when its not already warmed up but once its warm you will have to give it gas for it to run, A lot of times they will smoke a little bit to but mine never did. Only one of my chokes were stuck open causing it to run really goofy but most the times they will both stick and make it run like crap and not idle, I had an 06 V-2 and all the V-2 Cats have cable issues, the cable goes down into a U and the water sits and corrodes the cable, the guy probably took the cable off like I did and oiled it up, these cables get water in them all the time and there is really no fix other than oil yours up or buy a new one and oil it up before you put it in. The cables stick and hold the choke open after they corrode, Its probably time to get a new cable if he already messed with it and its acting up again, some people have actually had these cables corrode and brake, I have a new in the bag choke cable for a 2004-2006 V-2 for sale, never been used, got it for mine then traded it in for the T-Cat and now have the new cable to sell. im asking $70 for mine being I paid $73.99 for it
Old May 27, 2008 | 12:00 AM
Tomhusker's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Sindelir
Its neither valve adjustment or idle adjustment, your choke is sticking causing it to start fine when its not already warmed up but once its warm you will have to give it gas for it to run, A lot of times they will smoke a little bit to but mine never did. Only one of my chokes were stuck open causing it to run really goofy but most the times they will both stick and make it run like crap and not idle, I had an 06 V-2 and all the V-2 Cats have cable issues, the cable goes down into a U and the water sits and corrodes the cable, the guy probably took the cable off like I did and oiled it up, these cables get water in them all the time and there is really no fix other than oil yours up or buy a new one and oil it up before you put it in. The cables stick and hold the choke open after they corrode, Its probably time to get a new cable if he already messed with it and its acting up again, some people have actually had these cables corrode and brake, I have a new in the bag choke cable for a 2004-2006 V-2 for sale, never been used, got it for mine then traded it in for the T-Cat and now have the new cable to sell. im asking $70 for mine being I paid $73.99 for it</end quote></div>
I had a suspicion it was something to with the choke/cable. It does't feel right or, like I said, idle right when the choke is engaged. I'll have the local guy look at it as I have a tendancy to booger up things when I tear into it. Thanks.
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
MNatv89
Jul 7, 2015 11:36 AM
