tboss HOT?
Old Jan 22, 2001 | 12:39 AM
BillNikkanz's Avatar
i have a 00 tboss 325.... i took it out of the back yard this morning and loaded it on the trailer it seemed to be running fine..... i didnt run it all day(making mods to the trailer for 2 quads instead of one). late in the evening i turned on the keyswitch and i heard the oil cooler fan come on..... i started the bike and it seemed to be running fine, then i put the bike in gear and immediately the hot indicator light came on....... what could this be? could it be a bad sensor or switch? has anyone else had this kind of problem? i havent had the oil lines replaced yet but my dealer has them on order....
Old Jan 22, 2001 | 02:50 AM
Dazed's Avatar
Check all the electrical connections and put dieelectric greese on each connection You have a short somewhere or maybe a bad ignition switch. Also check your ground from the frame to the moter.
Old Jan 22, 2001 | 12:00 PM
BK's Avatar
BK
It is a bad temperature sensor. I had it happen on mine and a friend had the same thing. I have heard they had a recall on this for 325 Magnum but somehow not T-Boss even though it is same engine. I just unplugged mine (right on top of oil cooler) until I can get to dealer.
PolarisPete73
Aug 7, 2003 03:57 PM
rideitlikeustoleit
Jan 13, 2003 12:17 AM
rideitlikeustoleit
Nov 12, 2002 01:20 AM
325TrailBoss
Sep 15, 2001 03:00 AM
