Prairie 300 owners
Old Jan 22, 2001 | 01:03 AM
ROMAN's Avatar
I'd like to know if any of you have had any problems with your bike and what they were. So far I have had a ruptured brake line, a rear seal failure, a bent valve, and a belt replacement. I've got 1,300 miles on her and now it's making a ringing sound in the vavle-train when I use medium to high throttle. Nothing when Idling or off idle.
Old Jan 22, 2001 | 01:34 AM
Diogenes's Avatar
Ever adjusted the valve clearance? Sounds like loose valve(s).
Diogenes
Old Jan 22, 2001 | 02:03 AM
ROMAN's Avatar
Yep. Their in tolerance. Just checked them today. I wonder about a valve seat?
Old Jan 22, 2001 | 07:43 AM
Diogenes's Avatar
Then, there's the cam chain tensioner. Unless the plunger is free to move under spring compression, the chain will not be tensioned properly; this situation could cause some noise. Check the cam chain tensioner for proper operation and adjustment.
I doubt anything associated with a valve seat would make the noise you describe; if it runs o.k., I wouldn't worry about it 'till things get worse.
Diogenes
Old Jan 22, 2001 | 09:09 PM
14mins's Avatar
The only trouble with my 2000 model 300,the choke lever broke after 2 months. I never took it back in to be fixed. 10 months later i wish i had. Taken it in to be fixed Tuesday this week.
Old Jan 22, 2001 | 10:34 PM
jscyoung's Avatar
Roman, you said that you had a bent valve, so I assume you've already had some engine work done. Hopefully it was by a qualified mechanic. If you have more engine noise, why not take it to an authorized dealer and get it checked out properly? It should'nt cost much for an evaluation. Then you can decide what to do. If you keep running it and there is a problem, you may do some expensive damage. Good luck.
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
Ahtatu
Sep 28, 2015 12:14 PM
