02 440ex problems
Old Jun 3, 2008 | 11:03 PM
viper23451's Avatar
Default 02 440ex problems
hi everyone hope you can help me i just bought a 2002 400ex last week. it has a 440 big bore kit, stage 2 hot cams, yoshi exhaust,jet kit, and uni air filter. the problem is it has a really bad tick to it but i have heard honda do have an issue with ticking but this one is bad and the oil pump was just replaced i think they need to be adjusted but i dont know what they are supposed to be at? i know the stock specs but it should be different right?? ok the other question is what kind of fuel should i be running?? i am using 93 octane now. ok thanks for reading and some help would be really appreciated
Old Jun 4, 2008 | 03:48 PM
go-hard-or-go-home's Avatar
ive put my life in my 400ex. ran awsome but it ticked. it had the same problem. now 2800 dollars later, tring to figure out the ticking, it was the timing chain. get a new chain and tentioner. do not get a HD chain just get a OEM one. i am will to bet its that.
Old Jun 4, 2008 | 04:14 PM
trxguy9780's Avatar
if not the timing chain then you should adjust your valves.
Old Jun 4, 2008 | 10:36 PM
viper23451's Avatar
i was told that the timming chain and gears were replaced with 450 parts because they are dual chain setup.
Old Jun 5, 2008 | 05:55 PM
Bounce400ex's Avatar
I would check that out to make sure. If you need pics to compare, let me know.
Old Jun 5, 2008 | 11:12 PM
viper23451's Avatar
thanks guys im gonna check the chain and the valves hopefully it will be one of those
Old Jun 6, 2008 | 08:00 AM
ScottM1989's Avatar
As for your fuel question, it depends on the compression ratio of your engine. Higher the compression, the higher the octane you need. Since it appears that you did not build the engine, see if you can get the info from the people that did.
Most 426 and 440 kits I am familiar with tended to be high compression kits. Without knowing what yours is, I wouldn't go any lower than 93 octane.
Old Jul 5, 2008 | 07:48 PM
honda440exnut's Avatar
I have an 02 eith a 440 kit on it and when I set the valves to spec it chattered bad so I called the company I got it from and it says they arent set to stock so if you know what compeny made it call them up and talk to there tech they will be able to tell you what there supose to be set at
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
