Will running without the spark arrester hurt anything?
Old Jan 24, 2001 | 07:13 PM
250rampage's Avatar
Awhile ago, I was cleaning the sparky on my 400ex, and longstory short, I stripped out a bolt for the spark-arrester, and I haven't put it back on since. I would like to know if it's harmful to run without the spark arrester? Thanks. Oh, BTW, if needed I can retapp the bolt hole, but like the sound of it with no spark arrestor.
Old Jan 24, 2001 | 07:17 PM
RECON420's Avatar
I don't even know what a Spark Arrester is, but I'm sure you already know that, comsidering I own a Yamaha Breeze 125cc.......
Old Jan 24, 2001 | 07:20 PM
250rampage's Avatar
And, what exactilly does that have to do with this...Travis.
Old Jan 24, 2001 | 07:29 PM
RECON420's Avatar
To tell the truth, it had nothing what-so-ever to do with it, I just decided to say it! Just like this msg. There's no point, but i'm doing it anyways!
Old Jan 24, 2001 | 07:35 PM
wheeliedude's Avatar
I don't think it will hurt, but I am no expert on exhausts. I heard if you take your whole pipe off, the cold air that enters the header can hurt the valves when the engine is shut off. I have taken my spark arestor out a few times, and mine is still running good. It sounds awesone, but for a long trail ride, it would get to me. plus mud, water and other crap will find it's way in the back of the pipe. Just to be safe, I would keep it on. Unless someone who knows what they are talking about says otherwise. It still probably don't hurt.
Old Jan 24, 2001 | 08:52 PM
juggalo's Avatar
dn't worry about it my firned with a '00 400EX purposley took his off. we've had it in really deep water, we've had it flipped over in water, we've had it stuck in the mud, we've had it stuck in the water (multiple times for all of those) and its still fine.
Old Jan 25, 2001 | 04:44 AM
JRM's Avatar
JRM
You cant take the spark arrester out on stock honda pipes, only the bottom tray plate that dumps the carbon comes off. The baffle is also removeable with those 2 8mm bolts but that is just a silencer, not the spark arrestor as its strait threw. With the baffle out, look inside the pipe with a flashlight and you will see a turbin type deal and thats the non-removable spark arrestor. You can safely ride with the baffel out, but reamber we dont need more ATV haters out there that get annoyed by loud pipes. Joe
Old Jan 25, 2001 | 05:04 PM
250rampage's Avatar
Nope, It can be taken out on the 400ex, but what you described is the same system the recon has. Trust me, It can be taken out on the 400ex.
Old Aug 21, 2003 | 01:50 PM
Honda1478's Avatar
Default Will running without the spark arrester hurt anything?
I took out mine on my 250ex today, and it sounds awsome. Ill probably put it back on until I findout its safe since ive only had the machine for 3 weeks. I cant really see what damage it will do though.
2x_lung
1) Engine problems..
48
May 24, 2023 05:22 AM
TegraQuad
13
Nov 26, 2017 01:40 PM
Ty Speece
Jul 2, 2015 04:59 PM
sae156
Jun 3, 2015 01:45 PM
Glenn McDonald
Aug 26, 1999 12:46 AM
