99 sprotaman will not shut off
Old Jul 10, 2008 | 10:45 PM
tide's Avatar
Default 99 sprotaman will not shut off
I have a 99 500 sportsman and it will not shut off I replaced the ingnition switch did not solve the problem
Thanks
Old Jul 10, 2008 | 11:07 PM
With key turned off does emergency switch kill it? check grounds (brown wires)?
Old Jul 10, 2008 | 11:15 PM
tide's Avatar
I will check the wires but the kill will not stop the motor with or without the key on
thanks
Old Jul 10, 2008 | 11:18 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
hey tech, isnt that a basic grounding out system when you turn the key to off or hit the kill switch?
Old Jul 10, 2008 | 11:52 PM
Thats why I asked about the kill switch also,if that doesnt kill it,short somewhere sounds like. Have had switches go bad before that you would turn off and kill only with emergency switch! Usually happened on the old 2 position switches with starter and kill switch combo. Just thought of something else. check to see if black wire from cdi is connected. This is kill switch to cdi. Just a thought!
Old Jul 14, 2008 | 11:22 PM
tide's Avatar
Thanks i think you are right if i shake the harness it shut off
Old Jul 15, 2008 | 10:58 PM
tide's Avatar
I check all of the grouds and they test fine the switch also test good the atv runn runs for 20-30sec after i trun the key off I also changed the cdi and it made no change what should i check next ar can i just hook up a kill switch
Thanks
lonerider856
Oct 13, 2023 03:45 PM
Customer Service #1
May 15, 2020 08:46 AM
mrtidy
Feb 3, 2016 05:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
Matt123
Sep 29, 2015 01:29 AM
