xpolorer front wheel popping
whats going on guys.I have a 95 xpolorer 400. my awd on the left works fine the right side most of the time dont work. ever now and then it will grab and pops is this the cage bad,if so seem like someone said you can get this at the john dreer. if so would i need a part number
thanks for your time
Pull off hub,check bearings,hub and strut seal especially if fluid low for leaks,check armature plate for excessive wear rings on back side and if seems stuck to coil on strut,check roller bearings,spring,cage on hilliard assy. MOST awd problems due to armature plate or leaking seals. If run dry for a while can be a MESS! Also check inside hub where hilliard engages for pitting/rough spots. Hope this is what you are describing. Good luck.
KimSJoh
14
07-18-2015 07:20 PM
JackTheKing
07-14-2015 09:09 PM
