Carb ? for a grizzly 660?
While sitting on the bike. Choke cable is cable that screws into the top left of the carb. Break the threads loose with a 12mm (maybe a 10mm) wrench. Once that comes out your done.
Throttle cable is on the right side of carb under a small plate. Find where the cable enters the housing the plate covers. There's 3 small screws on the plate. Once the plate is opened you'll see how the cable attaches. I usually use a small flat tip screw driver and a pair of needle nose pliers to remove the cable.
Careful not to lose the brass cable guide/lock pin once the cable is out.
RedRancher
Oct 15, 2020 01:45 PM
GregM
Mar 6, 2018 06:53 AM
