Carb ? for a grizzly 660?
Old Jul 11, 2008 | 12:46 AM
modnut's Avatar
Default Carb ? for a grizzly 660?
I'm trying to get my carb off but i;m not sure on how to take the choke cable and throttle cable off has any one done it? How hard is it?
Old Jul 11, 2008 | 05:33 AM
Malachi's Avatar
While sitting on the bike. Choke cable is cable that screws into the top left of the carb. Break the threads loose with a 12mm (maybe a 10mm) wrench. Once that comes out your done.
Throttle cable is on the right side of carb under a small plate. Find where the cable enters the housing the plate covers. There's 3 small screws on the plate. Once the plate is opened you'll see how the cable attaches. I usually use a small flat tip screw driver and a pair of needle nose pliers to remove the cable.
Careful not to lose the brass cable guide/lock pin once the cable is out.
RedRancher
Oct 15, 2020 01:45 PM
greg74
Sep 10, 2019 03:03 PM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
