what is this button
Old Jul 17, 2008 | 04:58 AM
eschesworld's Avatar
Default what is this button
i have a 1990 2x4 250 trail boss or blazer ? and on the left handle bar is a little button that when pressed with eng running will smoth out and raise the idle . what is it has 2 wires to it.
Old Jul 17, 2008 | 06:22 AM
MaineWheeler's Avatar
Does it do this in reverse or all the time?
Old Jul 17, 2008 | 07:22 AM
Sidewinder500's Avatar
its prolly the reverse override button so you can go full speed in reverse
Old Jul 17, 2008 | 08:24 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
all auto polaris have that little yellow button called an reverse override ride button. in the case for your bike it is so you will have fullpower/speed in while backing up. its designed to cut out the engine when its not being pushed in while in reverse for safety reasond.. welcome to the forum.
Old Jul 17, 2008 | 11:10 AM
sounds good .it does change the idle in all gear ranges though. without pushing it the idle is loapinglike a old hit and miss engine.press it and she is smoth.
Old Jul 17, 2008 | 12:19 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if its doing that in forward and reverse and doing it at idle, someting is wrong w/ the override. check to make sure the wires arent all corroded or the transmission switch isnt bad. this switch tells the override what gear your in so its not suppose to work while in forwards.
Old Jul 17, 2008 | 12:39 PM
blaster24's Avatar
yhea check your override button!
Old Jul 17, 2008 | 11:58 PM
Reverse limiter modules prone to failure on early models. Just pull black wire from module under headlight area that goes into terminal board. black kill wire there also. If doesnt kill with switch,wrong wire pulled! Or pay about $70 for new module,jmo not worth it. Will have full speed in reverse eliminating button. I Do it for customers frequently! Hope this is your problem,Good luck.
flyin-lowe
Dec 1, 2017 03:18 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
