Baja 90 oil problem
Old Jul 28, 2008 | 11:51 AM
nicks-matt's Avatar
Default Baja 90 oil problem
Hi, I have a 90cc baja that seems like it has no oil pressure. When I got it it had a broken piston and block. I put a brand new piston and block on it and fired it up. Right off the back I could tell the engine seemed to get tight after it ran for about 30 seconds so I shut it down and pulled it back apart. The piston had scrapes on the top and bottom and there was no oil getting to the head. Is this a pump problem? How do I check? Yes it had oil in it. Can someone help me diagnose this problem.
Old Jul 28, 2008 | 12:50 PM
luvmysxs's Avatar
sounds like you have eaither a bad oil pump or the screen below the oil pump is plugged. remove the right side engine cover, in front of the clutch is the oil pump, just below the pump is the filter screen, use needle noise pliers and remove it , it just slides out and see if its plugged, if it not plugged then go to e-bay and order a new oil pump, they run just around $10.00 plus shipping
Old Jul 29, 2008 | 12:49 AM
nicks-matt's Avatar
Thanks for the reply, I took the right cover off and checked the screen, it had a couple of very very small pieces but nothing that would block the flow of oil. I was thinking my pump is not working too. You think thats whats wrong?
Old Aug 7, 2008 | 11:30 AM
nicks-matt's Avatar
One more question,,Is there a way to get the clutch off without the tool?
Old Aug 7, 2008 | 12:54 PM
luvmysxs's Avatar
i made a clutch nut removal tool out of a 11/16 socket, i can send you a picture of it if you want. just send me your e-mail address. send it to luvmysxs@yahoo.com
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
TheHood
Jul 26, 2015 09:51 AM
hondarider1234
Jul 21, 2015 11:53 PM
