wolverine reverse override
Old Jul 30, 2008 | 08:54 PM
wolvy84's Avatar
Default wolverine reverse override
I have a 2006 wolverine 450 and was wondering if anyone has installed a reverse rev limiter override? How do you install it? Can you still have the rev limiter work even if you have the reverse override installed?
Old Jul 30, 2008 | 11:28 PM
chevy68's Avatar
yes it is easy and works very well....tap into the green wire off the cdi box ( might be green and white ) to a toggle stitch and a ground wire to the frame and other end of the switch.... when installed correct when in reverse the reverse light will shut off when bypassing the limiter ! normal when the light is on..
good luck let me know if you need more help.
Old Jul 30, 2008 | 11:45 PM
wolvy84's Avatar
So you just splice a toggle switch in the green wire and to ground? Then when you want to override the reverse limiter you just flip the switch and when you wnat the limiter to work flip the seitch back? How do you like your zilla tires?
Old Jul 30, 2008 | 11:59 PM
chevy68's Avatar
yes it is as simple as that..... love my zillas.... they grip very well and are very light.....
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
poutlaw525
Sep 9, 2015 03:19 AM
