98 Polaris Driven Pulley
Old Aug 1, 2008 | 08:35 PM
bdyck's Avatar
Default 98 Polaris Driven Pulley
I took the driven pulley apart and now I don't know which hole of the three the spring goes back into. What is factory? Could not see where the spring was originally. 98 500 Sportsman.
Old Aug 1, 2008 | 10:44 PM
Original setting is 2-2 If havent done before,place spring in helix(upper) and install in second hole at bottom,ALIGN wider spline in helix into wider spline on shaft,push down slightly,hold upper clutch sheath and helix while turning bottom sheath counter clockwise 1/3 turn, hold both sheaths and knock helix down (helix normally will stay down) either install circlip with free hand or can use c-clamp visegrips to hold sheaths while installing clip. Upon release,clutch should snap back and you should be able to feel spring tension. Good luck
Old Aug 2, 2008 | 09:40 AM
bdyck's Avatar
Thanks
Old Aug 2, 2008 | 10:42 PM
ftwflh's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: old polaris tech
Original setting is 2-2 If havent done before,place spring in helix(upper) and install in second hole at bottom,ALIGN wider spline in helix into wider spline on shaft,push down slightly,hold upper clutch sheath and helix while turning bottom sheath counter clockwise 1/3 turn, hold both sheaths and knock helix down (helix normally will stay down) either install circlip with free hand or can use c-clamp visegrips to hold sheaths while installing clip. Upon release,clutch should snap back and you should be able to feel spring tension. Good luck</end quote></div>
That is the best instructions I have seen on how to do that[img]i/expressions/beer.gif[/img]
Ramman1
Aug 11, 2022 01:53 PM
RickyMac
Mar 5, 2016 07:27 AM
NoJoke
Aug 9, 2015 12:39 PM
Desimation2k8
Jul 17, 2015 12:37 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
