Sport Quads Discussions on sport quads.
85 230 quad sport needs HELP
Old Aug 2, 2008 | 02:06 PM
stepside's Avatar
Default 85 230 quad sport needs HELP
[img]i/expressions/face-icon-small-disgusted.gif[/img] Ijust pu rings in my quad sport and now i can't get it back in time.tried it both ways and it has not started could someone help
Old Aug 2, 2008 | 04:09 PM
JustRandy's Avatar
Just because it won't start doesn't mean its out of time. The spark fires on the compression and the exhaust stroke... Kinda hard to get it out of time actually.
Did you check the valve clearance? Do you have spark?
Old Aug 2, 2008 | 05:55 PM
stepside's Avatar
i have gas fire and compresion,it just will not fire,even put gas in the sparkplug hole.did not adjust the valves.just took the head off.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Aug 2, 2008 | 06:12 PM
JustRandy's Avatar
If the intake valve is too tight, it will not start cold.
There are marks on the cam that must be level with the surface of the head when the piston is TDC. That's all there is to the timing. As long as the piston is at TDC and those marks are parallel with the head, you can't go wrong.
If all that is good, then I guess you forgot to plug up a wire or something. Maybe your kill switch is off. Gotta be something simple.
Old Aug 3, 2008 | 01:01 AM
stepside's Avatar
ok i will go back and double check everything,the pisyon is at TDC,ahe marks on the cam are parrelle.THANKS ALOT for your help[img]i/expressions/beer.gif[/img]
Old Aug 3, 2008 | 02:18 AM
JustRandy's Avatar
No problem. I just put one together tonight and it started right up.
Old Aug 4, 2008 | 09:56 PM
stepside's Avatar
hey randy got it running yeaterday,it was the ground wire was in the wronge spot, THANK YOU FOR ALL YOUR HELP. this was the first time i have a 4-wheeler, you were right it was something simple. thanks again.[img]i/expressions/face-icon-small-cool.gif[/img]
Frisky2050
Apr 9, 2020 11:19 AM
RickyMac
Mar 5, 2016 07:27 AM
1988josh
Ask the Editor
Jul 16, 2015 09:43 PM
John Boy
Jul 13, 2015 11:16 AM
black_thunder
Jul 9, 2015 05:58 PM
